I have a 84 T-type that I intercooled and changed the intake /TB/TPS/IAC over to 87 GN parts. Once I got it together, I felt that my 84 MAF was failing because it was running super rich. I took the MAF out and it was really dirty. I replaced it with a newer 85 MAF that had hardly any miles on it. The 85 MAF is smaller and shorter than the 84. It's not exactly like a 87 MAF, but it is closer to an 87 than a 84 in looks and dimensions. The car is occasionally backfiring on start up and coughs and stumbles at about 5lbs of boost. The problem is worst when the car is cold, but still happens to a lessor degree when it gets warmed up. When I sit at a light, the O2 numbers are at 800. Under acceleration the O2 numbers are perfect at about 760. While cruising, the numbers vary from 020 to 750. Fuel pressure is good, spark plug wires have been tested, spark plugs have been checked, coil and module have been replaced. None of these things had any effect. My Turbotweak chip is burned for the car when it wasn't intercooled and had the 84 MAF on it. I haven't been able to get in touch with Eric via the telephone and only somewhat via email. Has anyone had experience with a situation like this? Should I just change to an 87 MAF and mail the chip back to turbotweak for alteration? Can someone get in contact with Eric? This is my daily driver and I can't afford to be without it for more than 3 days. Am I diagnosing the problem wrong?
