Tv Cable
Hey Mike, do you happen to know the factory part number? I might have NOS. Gotta check the parts stash.
Well the part number has worn off the packaging. Here are photos, you be the judge if correct. Package was sealed until I just opened it.
Well it sure looks like it. Could you please measure it and give me an overall length.
What do you want for it mailed to me out here at 99212 ( Spokane, WA. )
Thanks Mike
hey guys I'm curious on length too mines 43" or very close
It depends on how you measure the cable assembly... Here is what I come up with. If you slide the metal cable flush with the plastic housing at the transmission end it measures aprox 39" total. Just the plastic housing is roughly 36". See pics. In both situations I'm pulling the cable tight.
I measured mine with the end that clips into plenum bracket pushed in , total length of entire thing tip to tip just under 43
interesting
I may have a used original one laying around. Who knows where it's at in my attic! I would have to compare to see how they measure up.
Hi, Did you ever find one to compare it to? PM me what you want for it mailed to 99212 ( Spokane, WA. )
Thanks Mike
Hello, I just found the spare I had for my 86-87 cars. Grass Doctor is correct. My original 86-87 cable is right at 43". I wonder if my OEM TV cable is for 84-85 Turbo Regals? I have had several parts and parts cars ranging from 84-87 over the years.
Here are some pics
clip is metal on the 43" one too
thats the one I have, we had the same problem at Bruce's he had a lot of shorter ones and only one or two of the longer ones but packages/bags were so old and deteriorated could not read part numbers , ill bet shorter ones are for 84/85 , the mystery continues
good info thx for sharing turboWh1
