Twin Alky Kits-progressive
87buickracer
Twin alky kits running two m15 nozzles,with turn on points in stages like two stage nitrous..My plan is to crank the boost up with air/fuel ratio around 10-8 to 11-2..car is currently in tuning phase and so far I'm up around 18 to 20 psi boost with pt72 turbo..If you guys read my fwd roller lifter thread,this is the engine..so far I have broken two rocker arms and have since went with rjc rocker braces with no further problems..I will run these rockers until I obtain some t/d roller rockers..It took me a while to get the turn on points just right..but just had a flat tire last nite on my friend's drag radials..Spun the bead on the rim doing a burn out,so I'm putting my street tires back on..once I get this thing dialed in I will post up some numbers..
note-check out the traditional vise grip on the hood shock-awesome..lol..
The ISAC would be a perfect controller for what you want to do. You can control both pumps through one controller.
Edit I see the two SMC tanks...
I think with a 72 it should run 9's
yep,kinda chicken on turning the boost up..
car pulling so hard at 20lbs feels like the rear end is about to come out.(lol).:biggrin:
Time to put in the moser axles...
around 50mph,tires start to lite up...
I'm sure it should be in the 10 second range now..not sure on horse power level at
20lbs though...
That sounds like a nice feature to have..maybe when the funds allow I will give you guys a call..I'm curious to see how these two kits will perform at the track...should have a set of tires in a couple of weeks..last week I went to two tracks,got rained out and had a flat tire on the way home..so hopefully I will get a run soon..
