Update On The 84
7tcutty
ILL try to post my stuff over here as the car is a HA
anyways
the car was running like crap so i starting dismantling it DP off UP off and changed out the plugs the old ones were r44ts plugs i switched to cr43ts plugs all except 1 HOW THE HECK DO YOU GET THAT #6 PLUG? i found the pcv valve hose had come off. fixed that
the car now idles very very well now. i will actually start on its own when cold and idles down after starting. i have two things now. the car surges at idle in park (prior experiences tell me to clean the IAC VALVE) and i have a strange tapping sound every once in a while i cant quite tell where its comming from its not there all the time its sounds as if something is loose its not a rod bearings cause ist intermittent. i did shut it off and i sounded like a wheel in the turbo maybe tapping?. tomarrow i am replacing the rear breakline bleeding the brakes and i am going to try to build some boost. it wont build any now the tires keep breaking loose and its got 255-60-15s on it!
i also will drive it around the neiborhood after that stuff is done. so i can see if its doing what its supposed to or not.
THIS SITES AND GNTTYPE HAVE BEEN A HUGE HELP TO ME THANKS !! my first turbo car was a 86 tbird turbo coupe. that car was a lot of fun. now i got two more cylinders..
im gonna try to save this WH1 its getting closer and closer to a yes
KJW
7tcutty said:
....... HOW THE HECK DO YOU GET THAT #6 PLUG?
.........its sounds as if something is loose its not a rod bearings cause ist intermittent. i did shut it off and i sounded like a wheel in the turbo maybe tapping?.
For the plugs I use a long 18" extension and a swivel.
Use some masking tape around the swivel, socket and extension connection so the socket won't come off while trying to get the :mad: plug out.
The tapping noise is most likely not the turbo.
Could be a sticking lifter. :confused:
