All parts from running `87 TR's unless otherwise noted:
_____________________________________________
Cam with matched lifters, very low hours: $80.00 set
20 bolt oil pan with baffle: $45.00
Good 120 volt O.E. alternator with pulley: $45.00
Belt tensioner with pulley: $45.00
Concert Sound grey right lower door panel with CSII speaker cover: $40.00
Oil cooler adapter with hoses: $35.00
IC shroud w/o scoop, includes black Rubbermaid big mouth trash can air grabber (installed and loose pics available): $30.00
Front GN swaybar: $25.00
Low fuel light module: $25.00
Stock timing cover (2 for sale): $20.00 each
Oil filter adapter: $20.00
Starter with solenoid: $20.00
Turbo oil return line with block adapter: $20.00 set
Turbo oil return line: $15.00
Original GM rear shocks from 32K car: $15.00 pair
Rear lower control arms: $15.00 pair
Pass. side Kirban breather with FREE bright nickel-plated valve cover: $12.00
Pass. side intercooler bracket: $15.00
Water pump: $10.00
Water pump pulley: $10.00
Lower pulley: $10.00
IC fan adapter only: $10.00
1984 ECM holder with cover & kick panel, dark red: $10.00 set
Blue mesh ratchet tie-down with stainless hardware: $10.00
Main cap bolts for 109 block: $10.00 set
NOS Discontinued GM Coolant bottle cap, also fits Razor's GN alky bottle (2 for sale): $8.00 each
Stock vacuum block for throttle body with new gasket: $8.00
Crankshaft bolt and washer: $5.00
Crank sensor bracket only: $5.00
Dual gauge 2 5/8" grey A-pillar pod: $20.00
Autometer 2 5/8" 20 psi Pro Comp liquid-filled Boost/vacuum gauge with tubing: $20.00
Autometer 2 5/8" 2-hole black aluminum gauge panel: $6.00
_______________________________________________________
Pics available. Buyers pay actual shipping. Parts are ready to ship.
PayPal, MC/Visa (no fees) & Money Orders are fine.
Thanks for looking,
Jimmy Johnson
Toledo, Ohio 43605
__________________
Water pump: $10.00
Thanks for looking,
Jimmy Johnson
Toledo, Ohio 43605
__________________
