Upper Radiator Hose Support
Steve87GN
Oh come on...its just a 6
Can anyone post a picture of what this is supposed to look like? Just got my car back from some work and this was not attached and now looks a little bent. I'd like to straighten it up to what its supposed to look like before I re-attach it. Also, my memory is a little fuzzy. Does it attach with the same nut that holds the IC bracket to the accessory stud or does it have its own nut? If it has its own nut, anyone know what it is off-hand? Thanks as always!!
It’s flexible so find where it looks best and is away from the pulleys.
It does attach to the ac stud
Thanks, but does it have its own nut or does it use the same nut at the IC support bracket?
I bent the sharp edge down on it bc it use to rub on my other maF pipe I have different one now
lol Good thing is that nut is there, so I can fix it. The bracket just didn’t get put on. Easy peasy!
