Interested in converting to vacuum, how did you do it? Is there a manual to read or print to read and see how you did that...
How much work, time and parts needed, why did you switch?
Brett
GNregistry@aol.com
Very, very easy. The parts swap took less than 3 hours not including bleeding the brakes. I probably could have done it in even less time but I got distracted and ended up fixing a couple of wiring issues I found under the dash.
As far as a manual, I purchased a complete kit from another board member and it came with a brief but effective step by step explanation of the process. The process basically goes like this:
1. disconect battery
2. remove brake fluid from powermaster resevoir with turkey baster or syringe
3. disconnect electrical connections from powermaster
4. disconnect brake lines from master cylinder
5. remove old brake pedal
6. remove four nuts under dash holding powermaster to firewall
7. lift powermaster out of engine bay
8. put on steel toe boots and punt powermaster as far as you can being careful not to hit innocent bystanders :biggrin:
9. insert four mounting studs on vacuum booster through existing mouting holes in firewall
10. reuse four original bolts from powermaster to bolt vacuum booster to firewall (underdash)
11. install new brake pedal
12. connect brake lines to master cylinder
13. bleed entire brake system.
14. install TTA style vacuum block with port for vacuum brake booster
15. connect vacuum hose from vacuum block to vacuum booster with inline filter
16. reconnect battery
17. carefully test brakes
as for why I switched, this is the third turbo Buick I've owned and I've had problems with the powermaster in all of them. I've owned several normally aspirated g-bodies and they all had excellent brakes (same parts as what I installed on this GN) and I've read plenty of positive posts about the conversion. I've also talked to a few local guys who are running vacuum brakes and they have zero complaints. I decided to give it a try for myself.
HTH
Rob
