mechanical73
- Apr 16, 2005
hey guys, wanted some input from those of you who have converted over to vacuum.
I found an early eighties cutlass supreme vacuum booster and master cylinder. Then I tee'd into the PCV valve and bought a new check valve and filter and proceeded to install it in my 84 T-Type.
I've heard that the pedal should be changed as well but I didn't have one so I had to drill the pushrod on the master cylinder to get it to fit on the t-type's pedal.
After bleeding the master on the car, then bleeding each wheel (i've done it using both methods: farthest wheel to closest and vice versa) the pedal goes right down to the floor even w/ the car off. There were no bubbles left when I was done w/ the bleeding and I actually wound up flushing the entire system w/ new fluid due to the extensive bleeding.
I didn't check the booster prior to installing but if it had a bad diaphram it would give a firm pedal with the car off then get soft when the engine is running.
At this point, I'm really frustrated as to what the problem could be. Does it really matter if I didn't bench bleed the master if I bleed it in the car ?
Am I incorrect in my assumption regarding the booster diaphram ?
I actually stopped by Sears and picked up a vacuum tester unit to check the unit on the car; can this be done while on the car ? I would imagine so right ?
Did I tee in at the wrong place ?
Could the proportioning valve be shot ? how do you trouble shoot it ?
Is the fact that I used the t-type pedal causing incorrect master cylinder functioning ?
One thing I'm not too comfortable w/ is that even after all the bleeding i've done - i keep noticing some small specs of dirt/rust in the reservoir.
I forgot to mention that I installed new brake lines from the proportioning valve all the way to each rear wheel cylinder as I had a leak and wanted to be sure it was corrected. The fronts are fine.
Anyway - let me know what you guys think
thanks
Nelson
thanks
Nelson
