vacuum line to turbo
JSD69Vette
can someone please let me know which side of the vacuum lines from the Y goes to the actuator and which side goes to the turbo? This Y splits and one side is a straight shot the other goes off at a 45* angle.
Thanks for the help.
Some may advise that if you're not running a stock set-up, then you should run the hose in "test mode". Which is running one hose from the turbo to the wastegate and bypassing the actuator.
