So the guy rebuilding my heads told me I need new valve springs...he recommended 140lbs springs for my application. Does this sound correct?I've never heard of springs getting that high in our motors.
Yeah if you're gunna upgrade I would go with the 100lbs springs. You could probably run up to like a 120lbs but I wouldn't go any stiffer than that. But the 100lbs are probably your best bet, and you can just use stock LS1 springs I believe.
Nevermind the mechanic figured it out...he calculated for the wrong type of cam/lifters. He looked up the tta/gn cam style and found it different from he thought it to be...110-100 he said from calculation.
