valve springs
gnpoweredrail
What valve springs should I run with a 556 lift and 224 at .050 duration hydraulic roller??
Comp 926 941??
Comp 926 941??
Depends on several factors...... but in most street cars at low to moderate boost levels.... I think the consensus is around 130 - 140 lbs on the seat.
Behive around 300 Lbs call Comp Cams 1-800-999-0853 ask what they use in the Roller Kit that they sell for buick...
I have a roller cam very close to yours.....542 lift.....224-222...and i run 150lb valve springs, and im very happy with set up :smile:
