Since swapping cams about a month or so ago my engine has a bit more valvetrain noise. I know Ive heard of some cams causing more noise than others, I dont truly understand it but Ive heard it said (I could see lifters being the culprit, but I dont know).
Anyway, after hitting the car up a couple times last night I developed a little extra noise which I havent had a chance to pinpoint yet. It may have been a tapping but almost sounded like a "clicking" exhaust leak sound (maybe header gasket blew out?). Its one of the two, valvetrain or header leak. Which ever, it wasnt very loud, but bad enough to set off the knock sensor when I got on it a little bit (probably drivetrain then?). This has me wondering, is it necessary to retighten the rocker arm shafts? Or am I right with my theory on the lifters, and a different set of lifters would help?
Ive gone through a somewhat similar situation on another TR which had a ATR cam/lifters. Noise was worse than mine. Swapped the lifters for stock types from Autozone (or Advanced?) and noise went away, car ran great and faster (no more false KR).
The cam that I put in mine is a Speedpro 204/214 from Northern Auto (also got lifters from them).
TIA for any input you guys can give me. (I would just like to have a little bit quieter engine
 , with a loud single shot out the back
P.S. To make it more confusing, I could of sworn when I got home last night, I think the extra extra noise (besides the already extra valvetrain noise
 ) may have gone away
 . I will check when I get home from work and start it up.
