Am in the process of troubleshooting no spark on our stock 87 GN vin 7 and have found that there are 12.6 volts at the battery, 12.6 volts at the ECM, 12.6 volts at the fuse block, BUT only 11.5 volts on the circuit 439 (pink / black) pin on the C3I Ignition Module 14-pin connector. After disconnecting the C100 bulkhead connector, the ECM, C3I & ESC I am getting 55 ohms of resistance between the C100 connector and the circuit 439 pink / black pin on the C3I.
What may be worse is that I am getting continuity between the circuit 439 pink / black pin on the C3I and any ground connector. From my amatuer reading of the schematic I am pretty sure this wire should not be going to ground.
FYI - Car sat outside for 4-5 years. Have already installed new C3I, coil pack, crank sensor, ECM & Chip. Have also cleaned up the grounds and repaired a corroded splice from the + battery cable to the ECM.
This is a father - son project and we are very grateful for your help.
Many thanks in advance...
