voltage reading on TL 4.0
PaulRV6
Is it normal to show a 12.9-13.0 v reading at steady cruise going 55 mph? Had defroster on high and head lites on also.
paul
paul
Assuming you have a standard 120amp alternator, and the stock 8ga charging wire, that's close to correct. 13.2 would be better, but with age, all things "droop" ;)
With the double fans, and having to run A/C, and headlights etc. my load got to be too much, so I upgraded the alternator to a 200amp, and upgraded the charging wire to 4ga.
Now, with everything running full blast it never drops below 13.7 as reported on the aldl data stream. No load, it runs 13.9-14.0
Thanks guys, that makes me feel much better, I will cross that one off my list of winter "things to do". Thankyou again.
paul
