VP unleaded fuel
s turbo t
Did one of you tried vp unleaded 103 fuel . If yes at what boost
is it good for.:confused:
Depends on a lot of different factors... car's combo, chip, etc....
Doug C.
VP 103 Unleaded
I have used the VP 103 (at the pump) quite a bit lately
At $5.45 a gallon (from the local Texaco in SoCal) it is very pricey, but it saves running all over town just to save a buck
I use it with my Alchy setup (100 % Denatured Alcohol)
I have several 93 street chips that I have tried and I have the boost set at 18 - 20 psi all the time
I currently run a TA-49, 009's, Big Neck Intercooler, AFPR, External Wastegate, Hot Wired XP Fuel Pump, KB Ram Air Intake, Stock Heads, BRF Tranny with 3000 stall, Nitto DR's, Scanmaster, etc., etc., etc.
Runs great (12.8 @107), low to no KR, but hell on the rear tires
Gotta get some real tires (Slicks), 108 chip, some better gas, crank up the boost (22 psi) and see if I can tickle the 11.99's
Good Luck
Ray
