Here is some back ground information.
I have a Cyberdyne digital dash with an external VSS connected to the speedometer cable under the hood. The two wires from the VSS goes to the dash and then one wire from the dash goes to the factory Buick harness.
Now the problem that I believe to be the VSS buffer.
My digital speedometer work (appears) fine, the numbers appears to be stable & NOT jumping all over the place, when cruising. Comparing to my scanmaster2 the speed reads just about the same.
According to Direct Scan, my computer (after 5-7 minutes of driving time) is seeing speed jumping from actual speed based on speedometer to speeds up to 190 mph. ie. I am doing say 60 mph and the computer is seeing anywhere from 60 to 190 mph.
The speed is changes almost every frame (18.2 frames per second) according to DS. The sometimes it goes back to reading the same as the dash speed.
Has anyone had a similar problem?
I am planing on replacing the buffer, but just checking to see if anyone else has seen this situation.
Heck with my 300,000 plus miles driving a turbo Buick I have seen many unusual things.
This was causing me to have (or so I thought) a miss or engine cutting out. Actually it was the computer was shutting off the fuel because I was hitting the 160 speed limit in the chip. Upped the speed limit to 200 on my chips is working so far.
Gary
Gary
