Wastegate problem.
johnsTT
I've been working on my 84 T-Type again lately and decided it was time to make the wastegate actuator rod adjustable. Everything went smooth with the mods, but when I decided to check to see if it would hold pressure/vacuum the pressure side holds and the rod pushes out. I,m assuming the other side should hold vacuum, but it doesn't. My questions are:
#1-Am I checking this right or am I missing something?
#2-Where can I get another actuator if it is needed?
#3-What type of symtoms is this going to lead to?
Thanks for all your help in advance.
