SignUp Now!Doing away w/ the switch will result in no fuel pump relay bypass. Should the fp relay fail, and you attempt to start the engine, that sw will allow pump operation, once oil psi gets over 4psi. W/o it, it's AAA time, or you walk home.Yeah but what about the stock switch?? You can leave it unplugged?
My last T had a small manifold that I mounted at the AC box. I moved the gauge sender and the stock sw to that manifold. I used braided hose w/ clear plastic over it, to prevent the braid eating wires, paint, etc.
The new car is getting the same treatment.
Very good idea.. Thank you for the feedback
For water temp, I just removed the threaded 1/8 NPT plug in the driver side of the block, just above the pan and put the sender.
For oil pressure, I removed the stock pressure switch from the brass block under the turbo at the front bottom of the engine and screwed the sender right in it. This is the same brass block the turbo oil feed line is plumbed from.
1 other way to "beat the system", is to carry a jumper wire. U can jump from the alt power stud to the black connector that hangs loose near the back of the alt. Hooked up, the pump will run all the time....Still beats walking!
I don't think the dummy light for the water temp can be tied in with the sender. It's not working.
Huh?? What does the water temp sender have to do w/ the fuel pump power??
for the oil sender just go get a "street t" and install both the aftermarket and stock sending units. can take a pic of mines later if you need it.
