Originally posted by MG8T7GN
I'm thinking of building that wide band O2 sensor box on the DIY-WB page. Is there a preferred location for the sensor? Does it have to be about where the stock sensor is located or is in the downpipe close to the turbo an acceptable location? Thanks.
Mark
I've tried mine in several locations,
In the oem bung, just post where the converter would be and at the very end of the pipe, and haven't seen any huge change.
Later today when it warms up, I'll be running two WBs at a time and seeing if there is any detectable change.
It's not really a big deal anyway.
You tune for what your car likes, so as long as any error is constant then there is no reason to worry.
Part of the trick to the WB is that it's operating temp, is 800dC (yes, it's that hot). So it's not effected by EGT, unless your running insane EGTs and have the WB right at the port.
One thing that will happen is that the further down pipe the sensor is, the more it will average the readings, the longer the pulsations dilute with each other there is time for more reactions to take place post chamber.
