I did this writeup many years ago...if you don't have time and patience then pay someone to do it...also if you've driven the car a lot in the rain or washed it a lot you will most likely have rust...so be ready for that...my car was garage kept but just from washing I had some rust...mostly surface rust but did have a small hole where one of the spot welds used to be...also had to replace front channel piece that holds the weatherstrip as the edges were rusted pretty bad...by the way the car hasn't seen water since I replaced the weatherstrip...I removed the surface rust and laid on a coat of POR-15 to all surfaces...
