weld prostars w/tires
highboost
2- 15X8 & 2- 15X3.5 PROSTARS NEW 1 YR ,THEY ONLY HAVE ABOUT 500MILES ON THEM BFG RADIAL T/A 275/60/15 ON REAR
AND 185/15 ON FRONT ONLY HAVE 500 MILES COMPLETE W/ CHROME LUGS
$575. + SHIPPING
THANKS KEITH
Hi
I like the wheels an the price just wondered what the shipping would cost that would be a determining factor!! My area cose is 35903.. I know UPS is really expensive so DHL may be a good option..
WILL CHECK SHIPPING
AND WILL POST PICS WHEN I GET HOME TONIGHT
KEITH
LOOKS LIKE YOUD BE IN ZONE 5 FROM MY ZIP AND YOUD BE LOOKING AT ABOUT 80LBS SHIPPING WEIGHT AND $30 SHOULD GET IT
KEITH
pics
Interested! What is the backspacing? How close are the rears to rubbing? I'm in Texas. Put me in line. How much tread left on the rears?
Just incase you'd consider breaking up the set, I'm interested in the fronts.
What size are the fronts-185x70x15s? and also would like to know thw backspacing on the rims.
ill measure backspacing today.
rear tires do not rub frame rails (about 1.5 inches space) or inside quarters but you do need to roll the lip on the quarter if you lower your car.
rubber is as stated 500 miles on tread no burnouts, because right after i got them a head gasket let go so never got the chance to put any miles on them.
front tires are 185/15 p-metrics there is no stated aspect ratio.
keith
ok the back spacing is 3.5" i must also correct the tire sizes
they are 275/50/15 rear & 165/15 p metrics on front.
i apoligize for any inconvenience of possible missleading any one.
also adding pic of right rear tire.
keith
Thanks for the update - i thought the tires in the rear looked alittle lower than a 60s tire. they look good.
I'll pass for right now, so I don't hold anyone up. I'm looking for 4"bs. But I'm not ruling them out.
thanks,
