I was running at the track last Saturday and after the first pass my voltage light started flickering. I checked the alternator and sure enough it was going in and out of charging so it was on its last leg. This is a points series I am in and figured if the battery held out I wouldnt have to disqualify myself. My laptop has a bad battery so its hooked up to an inverter which for obvious reasons I couldnt run. I didnt really want to run the car so I skipped the rest of qualifying and put a time of 12.35 on the window. I promptly broke out on that time and shut it down.
I had a friend bring me to a parts store that was open 24 hours and while I was off doing that another friend (mechanic) took my alternator out of the car. After everything was reinstalled it fixed the issue and my charging system was back up to par. I took it out to log a pass as I am still working on my tune and found that even though I have logging set up to record at 20 frames/sec it looks like its recording at 5 frames/sec. Further looking shows 0 volts for the battery in dash I have set up.
This was a quick swap at the track and I have had a chance to make sure all wiring is where it should be but I would assume so.
MY question is, is there any way I can get this back working properly? I am going to try and just reload the tune and hopefully that works but if anyone has any suggestions that dont involve buying a new box I am open for them. I would go XFi but money is real tight right now and I really hope I didnt hurt my classic box.![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
