what is this box....security?
11secondgs
It also has a toggle to it which I don't think works?
Anybody tell me what this box is?
Also, do I need it? What does it do, and can I bypass it since I dont think my security system works?
i think your prolly right since the drivers front window corner sasy champion or something......Can I take it out and where do the wires plug back into.....the alarm doesnt work at all either....
How can I make this thing back to stock...
if you unplug that, it might trigger a kill switch or something. just trace the wires. if its an upper quality alarm with window switch and door lock abilities, the wires will tie in to those inside the kick panels probably, and if it has an ignition kill, that will be on the purple wire on the steering column I believe. It will probably also splice into the door light actuators which are behind the kick panels also, so when the door is open, it triggers the alarm. Good luck...sometimes those are really put in with the intention of not being able to take them out easily, but sometimes they are just thrown in.
I better just leave it alone becuase it does mess with the door locks when I start and shut the car off.
do you guys know where I can get a remote for it???
Can you open it up? If so you might be able to see who made it and a model. Then Google it. You might be able to find installation instructions which should guide you to take it out, follow in reverse, or contact them to see if remotes are available.
