what plug be best ?
richardv6
I am ready to install spark plugs in my new ta build motor and like sujestions on what best to use,i am using stage 2 heads on a oncenter 273cu .I plan on running pump gas and running 100%methanol.
Something with a non-projected tip.
Sure. But I am accustomed to running champion GN1 heads which use a 14mm thread, tapered seat, 0.7" reach. What is the thread on your heads?
Try doing a search. I do find it disconcerting that you have this high po big build and arent even sure what sparkplugs to run in it?
I was just asking opinions ,I did a serrch and have a idea of what I want to run just want to see what others are running with alky...no need to be a smart ass.
I run AR-472 thru AR-474 on my Stage heads. These are a tapered seat plug and .708 reach.
AG
those are the same plugs I run with GN1's. Readily available at advance auto.
