what size AN fitting for oil feed on turbo?
northerngn
Master Monkeywrench
anybody??? would like to install the turbosaver next weekend but i need to know what size an fitting to mount on the turbo for the oil feed line
it was the only part missing when bought used
-dan
-4 should be plenty.
1/8" npt is correct for a regular journal bearing turbo. If you have a newed double ball bearing. You'll need a fancy metric fitting with built in restriction.
This is PTE, not sure about Tnetics.
1/8-4. Too much oil can be bad news on the turbo. get a restrictor if you have a lot of oil pressure.
my bad i got my numbers mixed up
i have -4an loked on jegs and -6 looks waaaay bigger
-dan
I switched to-3 on my setup. I'd been running that on my PTE journal bearing turbo's for over 60k on my Talon with no oiling issues. I switched the GN to it since -4 is not needed and I get some smoke which I attribute to the turbo's oil seal.
Russell 642791 = 90 degree, 1/8th NPT to -3 male
