what size turbo can i go with
gnkid1987
i have an 87 Gn my mods are
3" downpipe
high flow fuel pump
adjustible fuel pressure regulator
high flow cat
2 1/2 hooker exhaust
exhaust cutout
scanmaster
kenne belle cold air intake
duttweiller modifed neck for intercooler
after market boost gague
i want to know how big of a turbo and injectors i can go with on a stock bottom end. i would like to go into mid-high 11s
Thanks Ray
What stall torque converter are you going to be using?
If stock, stick to the TE44 and a good chip.
it is stock
what chip do you reccomend
and what do you think the times will be in the 1/4 mile with a safe boost level
Crank up the boost! try 24psi with good gas, no cat conv. Get any chip you feel lucky with. Any good chip maker will help you. Buy a street chip first, then if you have another $75-$110, buy a race chip with more timing. I like the knock box feature from Red Armstrong. Ignors knock during launch. Everybody has a different opinion about the best chip, but if you don't tune right, any chip can suck. Have fun!
Scott
55's need a modded ECM. 50's, 57's, and 60's dont.
Whats wrong with the stock turbo? Plenty of low 12 second cars running stockers.
Some even in the 11's.
HTH
when i was replacing my uppipe i noticed that it was coated with oil and i toook off my intercooler i also had alot of oil.
do you think 50 will be suffecient
Is that the first time you removed your uppipe and found oil? Check it periodically, but it may be a one time occurrance. Unless the car is smoking, the turbo could be fine.
36# injectors are enough for mid-high 11's.
