You guys seem to run some small turbos
I dont mean that in a bad way at all !
It is amazing the times some of your cars are putting down at the strip and some great numbers coming back from dynos:biggrin:
All from running small frame turbos - that fit the application. It appears you guys are getting great power out of many of these smaller / medium sized turbos. turbos like the pt 54 pt61 gt35 etc
these cars must haul on the road when on boost . I would think the boost is almost instant , and must have lots of acceleration.
Anyway , I was wondering what turbo would be a better fit for more street driving friendly torque. I know it will be different for each and every car , but in theory:
Is it better to run a turbo with higher psi for more usable low end torque(a gt30r at 25 to 30 psi )
, or
would it be better to try a turbo with more air flow at lower pressures (gt 40, pt67 at 15-20 psi) ?
Yes I know this sounds like " is it better to run turbo in its specified efficiency range"
But how does this really work out on the street ??
any opinions?
