Whats my combo worth
badboy86gn2
"lord be with me"
Hey guys just wondering what i can get from the following
Te-60
cas-v2
green stripes
jj tb 62mm
power plate
big mouth
terry houstan dp
3in single shot
persion tc 2800-3200 stall
hot wire
slicks (going to be put on)
bst
smc alk(24psi) dual nozzle
scan master
magnacor plugs wire
ngk plugs
tps-tec
tie down strap
dual fans (ramcharger)best bang for the buck
I just wanted to know whats the best even at sea leval im pretty happy with it as it pulls like a train through all the gears
THANKS
ROC87,CRASH,CHUCK,BOTLEFED and everone
What green stripes?
With 30# green stripes, good luck running an 11.
with 42# green stripes, you should be good for low 11's with 28" tall tires, race gas and chip. High 11's low 12's with alchy and a street chip.
sorry about that guys yes there 009s and if i had a flat bed i would take it to LV
He's running 19.3° WOT timing, around 23-24# (SMC alky) and for now he's running extremely bald drag radials:eek: . Figured I'd post info for him........Has a set of slicks, just not mounted yet:rolleyes:
Mid. and low 12's if he can hook.
I have learned drag racing isn't as easy as bench racing.
I did run a 13.5 in the GN pump gas and alky. with a 1.9 60ft. :)
4000lb. car. :D
Shoot for 12's and be happy.
And get a good race chip for the 11's with da good fuel.
No expert here just a realist. :cool:
I agree with ya salvage, go to the track, turn off the alky, leave the boost alone, put in some 116 and up the chip to have around 24-25° and it should be 11's with a decent launch. (With a good set of tires!)
