what's my next mod??
Matt Sando
here is what i have...
motor is all stock
stock turbo
RJC powerplate
Trasher Chip
Cold Air Intake
Throttle Enhancer
Heated O2
Big Mouth Intercooler
Adjustable wastegate actuator
Electronic boost controller
orange strip convertor
Looking to do some more bolt on's that will make a difference. Before I upgrade the turbo. Thanks Matt
next mod
First mod should be a Directscan system and then a PAC alky kit and TurboTweak alky chip. Install it crank up the boost and have some fun.
87 GN basic mods, alky,TT chip
Mods
scanmaster or direct scan, exhaust, alcy and TT chip, crank it up to 20# or so and Then you'll really need good tires! Good Motoring
next mod?
Get both the Scanmaster and Directscan if you can, but if it's only one go with the DR. It is by far the better of the 2. I currently run 21 psi on pump gas with Razor's alky kit and TT chip. I'm going up to 24psi soon with a few more mods. Good luck and run the heck out it.
Chris
