I know 5x4.75 is it, but in mm isn't it 5x120.65? Will 5x120 wheels still fit or does that .65 mm really make a difference? I see a lot of wheels with 5x120 pattern to choose from.
I wouldn't do it. Even if the wheel fits over the stock bolt pattern, tightening lugs is going to put a lot of asymmetrical stress on the wheel's lug seat, potentially weakening the wheel or leading to stress-induced cracks in the wheel.
i've seen alot of guys on the protouring.com site using the BMW wheels with the 120mm pattern with success, you should ask the and see if they use adapters. HTH
