Wheels & Tires How Big
led3147
led3147
Newb-hi Everybody Does Any One Know How Much Tire & Wheel Can I Put On The Rear Of My 1987 Regal T? I Would Like To Run 295-50-15 Tires On Crager SS 15x10 Wheels With A 4 1/4 Back Space. Does Anyone Know If This Work. The Tires Are 26.1 Tall About 10 Inch Wide?
Might stick out a little bit, I think you'd risk rubbing on the body more than on the frame, 4.5" backspacing is pretty safe as far as the inside of the wheel goes, but it'll be close to the fender. You might want to run air bags just to keep the body lifted up.
Here's my old setup, 10" wheels with 4" backspace, 325 M/T street radials, stuck out a bit too far:
Notice the wheel itself stopped right at the fender but those M/Ts are huge and stuck out too far, I think you'll be better off with the 295s.
