May 11, 2009 #1 D dsa87gn Member Joined Sep 9, 2002 Messages 703 what else should be replaced ? i fugure a new oil feed line Is a gasket necessary between the header and turbo, I see those expensive copper ones around, are they needed ? anything else
May 11, 2009 #2 B BlackMetal Active Member Joined Sep 29, 2005 Messages 4,688 Replacing the feed line is a great idea. I don't use a gasket at the header, just a bead of high temp copper RTV. You'll need the little gasket for the oil drain line if the turbo didn't come with it.
May 12, 2009 #3 J jerrad Member Joined Aug 21, 2004 Messages 534 Oil return line if the stocker is leaking.
May 13, 2009 #4 F fbodlovr 1/4 Mile Freak Joined Aug 14, 2005 Messages 703 jerrad said: Oil return line if the stocker is leaking. Click to expand... Have fun replacing the oil feed line.
