When should i lock my converter when i run??? Mods are pte53, stretch IC, 206/206 weber roller, champ irons, thdp, 9x11 3200 stall converter, etc, etc.....Thanks for the help!!!
your motor being close to mine power wise id say lock it from the start...it wont lock till after it shifts into second and if ours makes torque as well as mine does it wont hurt you a bit ..
for slower cars locking then that early can slow em down but once you get to where you are the motor will handle it and pull its a** off
Originally posted by Vader 87 When should i lock my converter when i run??? Mods are pte53, stretch IC, 206/206 weber roller, champ irons, thdp, 9x11 3200 stall converter, etc, etc.....Thanks for the help!!!
At your level of performance, you will get the best results by locking it a couple of seconds after it shifts into 3rd.
Turing the switch on at the start of the run and causing it to lock as soon as it hits second gear is awful hard on everything, will bog the engine too much, and could hurt your times. It however won't hurt the rpm's quite so bad if you're running a single disc converter because of the clutch slippage, which will soak up some of the harshness.
If you were running a multi disc clutch, the lock going into second would create a TERRIBLE bog and power loss.
