where do i get wheel spacers to put gta wheel on my regal
gnxregal563
i was told i need a wheel spacer to put the trans am gta wheels o my 83 regal
where do i get these spacer and how thick are these spacers? thanks
If you are running the front GTA rims all the way around then you probably get by without spacers depending on how much tire you want to run. If you are running front & rear GTA rims then you will need to run the front rims on the rear & the rear rims on the front with a spacer, probably about 3/8" or so. I run fronts all the way around with no spacer, so my front passenger side rubs slightly at full right tilt. This can sometimes be corrected by centering the body on the frame more, which sounds like more work that it is worth to me, but just my opinion. I think that Summit has some spacers, but not sure. HTH
I just bought adapters off E-bay to put Rears on the Rear. The fronts fit in front or rear without mods.
Ebay search
1.25" is perfect. Here is a link for a set, but if it goes bad search "camaro S10 wheel spacer" without any dimensions like 4.75 or 1.25, because that would be too logical.
$60 shipped for a pair is the number.
Make sure they are 4.75" bolt pattern for both holes and studs.
