Where do you hook up the Tach lead wire on 84-85 hot air car?
RussellinNC
Car lover!!!!!!!!!!!
Posting this for a friend.
Russ
:cool:
should be a green wire next to coil pack that is not running to anything this is just what i remember hearing never hooked one up
You are right, it is in that mess of wires under the coil module. It is one wire with a single connector.
Right Tach
It has to be a tach for distributorless ignition. Use the wire under the coil pack ( should be green with a plug to no where )and your good to go.
