Is it a stick?:tongue: :tongue: :tongue: :tongue: :tongue:
Seriously, there is none.
If you look on the tranny pan, there is a big nut and a small nut (torx) within the big nut. You need a special tool to fill the trans up. If you do a trans fluid change, you put in a certain amount and then start up the truck with the small nut out. You keep pumping in the fluid until it starts coming out.
Billy T.
gnxtc2@aol.com
