I am looking for an ECM that has inputs for boost/alky based off of 3 position switches. Namely 10psi/ 15psi/ 20psi/.......No alky/ 25%/ 50%..... I doubt if this is possible but if it is it would make a good project.
I suppose the boost toggle switch could in someway effect a boost controller that has the 3 settings preset, and possibly the alcohol setup could be hooked up to the alcohol controller and have the toggle just set the flow rate on the alky?
