which fuel pump to use
stevek
I was thinking on buying 60 # injectors and chip from TT, just wondering on which fuel pump most prefered, I already have hot wire installed,would also buy pump from TT, let me know thanks.
my setup is 93 pump gas, 60 turbo, smc methanol system single nozzle,applied technology front mount ic, powerlogger,scanmaster,translater,adj fuel pressure reg.,applied tech headers and down pipe with ptc cutout
Do I have to upgrade the fuel lines or are the stock ones big enough and is it a direct fit in the fuel tank , thanks
The DW-301. There is a huge thread on it in the E85 section.
Yes,you will have to mod or replace the return line,as well as the FPR.
There is a member here who did my FPR for $40. (E85 section again,same thread and with pics)
No regrets. Plus,it has a nice warantee.
If I can do what is necessary with the return line,anyone can.
