miketurbojinx
 - May 21, 2016
I bought the car about 8 years ago in Seattle and brought it back to Calgary Ab where I found out I had blow by 3 pistons so I had the engine rebuilt from the block up at dale adams automotive, The car came with a trunk full of parts ,Ta -49 turbo,50lb injectors,gn alky kit,thdp ,gn w/cutout,hardened rocker shafts w/retainers,polished aluminum maf pipe,k&n 8" filter,crome intet pipe,boost gauge,upper rad hose,walbro 340 fuel pump,fuel pressure regulator,timing cover,high volume oil pump,pro gear rollare timing chain set,cam button,,knock sensor,t stat housing,s/s includes o-ring,160 degree thermostat,angle boss housing,gn breather kit,by-pass v/c filter,100lb valve springs,fan delay relay,by-pass hose,intercooler hose kit from johns performance. so I put most of the parts on except for turbo,injectors,chip,alky kitfuel pump and regulator when the engine was being rebuilt and the car ran fine so I drove the car across Canada to St john's NL where I live now with out any troubles. About 3 years ago the car started to act up , it would start but idle rough and shut off so I parked it for a year  then I decided to have it looked at and the mechanic said the head gaskets where gone so I put arp head studs and new gaskets in the car whiched helped big time but still has a miss or hiccup while driving it so then I changed  tpc sensor,plugs/wires/coil pack,temperature sensor,fuel pump/filter,,turbo which is set at 13psi of boost and  changed to 50 lb injectors . it ran completely worst, so then I tried the new chip and it cleared up but yet it still has the hiccup while your driving down the road just putting along she will hiccup but when I shoves the pettle to the floor the car takes off and dosent miss a beat. I still do not have the alky kit hooked up cause id like to get the car running right first. ,please guys help me figure out whats going on with my car , I have about $45000 into this car and its driving me insane
