Josh Mohesky
- Aug 24, 2012
20lbs of boost on alky in 3rd gear and no o2 readings
SignUp Now!'20lbs of boost on alky in 3rd gear and no o2 readings
So it is a Yugo?
It's the scan master . I have loved these cars since I was in high school. Still new but want to get as much knowledge as possible. I read some other post about false knock and they said try to ease into it in 3rd and see if you see knock. No knock
it goes to zero at top end with no knock. ran the car last night and rn a 13.08 at 104. i also have oil coming out from the dip stick. the car has a TT chip Methanol injection and running 20lbs of boost. brand new rebuild
A Yugo was a car made in Yugoslavia. Little and cheap. I don't think it is made anymore. It's the only car to go over the guard rail,on the Mackinac bridge here in Michigan. It was windy.What is the Yugo ? Im new to this
Sounds like it is bad. You could richen it up to see what it does.Bosch
I just replaced it. I know th methanol isnt to good for the either
Reads normal at idle and cruising.
