turbotaone
- Jan 22, 2003
I just got my engine back together after replacing the head
gaskets. The only thing that I changed was I had the heads
ported while I had it apart. Now the IAC counts won't go below
60 no matter what I do. I've checked all the grounds, I've set
the TPS up and down, I even replaced the IAC valve, nothing
seems to help. Right after I replaced the IAC valve I thought that
I had it fixed, the counts went down to around 25, but when I
took it for a drive the car ran very bad, it would bog if I tired to
exelerate quickly. The car was running very rough and would not build any boost. I brought it home and parked it because I was
tired of messing with it. So I go out and start it today and let it
warm up and the IAC is back up to 80. I checked my TPS and it is
at 40, so I start adjusting it up and down a little, but it did not
help. I get the car where it sounds like it is idling normal and
when I look at the IAC counts they are between 60-90. I did
notice that when I set the idle up high the car seems to rev real
smooth(no bog or hesitation)when I stab the throttle.
What else can I try
James
What else can I try
James
