Wideband..
It will tell you what your A/F ratio IS, but NOT what it should be. Some time on a dyno will do that, and then you could use the WB to get back to the desired fueling, or you could use EGT and knock retard. If all you're going to have is a Thrasher 92, the WB wouldn't be of much use, since the Thrasher has "fixed" fueling. You could use it to adjust fuel pressure, but for a Thrasher 92, the gains would not justify the time and expense, IMO.
