Key thing here is going to be taking everything into account and planning out your suspension and brakes along with your wheel and tire combo.
It's always important , but since you want to go to pretty much the biggest wheel tire combo it will that much more important to plan ahead or match what you got now.
So what is your setup? What brakes are you running front and rear? Do you plan on changing them? Some brake setups will push the wheel out Alittle possibly cause interference. What are your suspension upgrades? A lower control arm that center the wheel a little more in the wheel wheel will also help in achieving your goal. I think ridetech speed tech spc and dse all offer these. A 275mm tire in the front might rub the front sway bay but I believe the ride tech muscle bar will allow enough room. Ride height will play a factor here as well. What wheel are you wanting to run?
Short answer , yes with a properly planned out front brake and suspension system will allow a 275-35-18. You may have to do some cutting on the inner fenderwells esp at the top to create a pocket for the tire. Any taller and I think you will have issues.
On the rear take the same precautions as on the front. You can run an 18x10 with 4.78 backspace without a notch and depending on ride height should be able to get away without rolling your quarter lips. I think Scott W. from GNS is running a 295-35-18 on the rear of his car but I believe he did roll the lips.
A good person to call would be John at ccw as he is very familiar with these cars and what will work with what.
Now you don't necessarily have to do all these upgrades to fit this wheel tire combo on your car, I was just listing out things that you should take into consideration before ordering a set of wheels. It's better to be cautious up front than to order a set of wheels and have them not fit.
1 last thing that may help is to make sure your body is centered on your frame. These cars are notorious for sitting off to one side and having more clearance on one side than on the other. Well hope this helps Alittle. Joel
