Assuming you have the original untouched fan and stuff.
Ok...the Fan shroud will have a caeramic resistor on it, the resistor is what actually makes the fan run on low speed. I do not remember the colors but wipe em off and bet ya the solid blk is GND. get a meter and verify, so the other wire left is high speed.
Easy way around all this.
Verify the ground wire and hook it to the GND/- on the new fan. The other 2 wires tie them together and hook them to the POS/hot/+ wire(s) on the aftermarket fan.
Now, no resistor and without it there is less amps on the system anyways. And no matter what position the fan relay low(originally the resistor or high without resist)the fan runs.
