Roosa50441
- Oct 1, 2019
I'm getting geared up to purchase my turbo. Need input on witch one. I have stock converter now but will buy a aftermarket one if I need to. So with that being said heres a list of what I have done so far..
60# injectors
8an fuel feel
6an fuel return
Aftermarket fuel pressure regulator
Will be building a 3 inch or 3.5 down pipe and be using external waste gate off the header
340 fuel pump
Will be running c16 at the track and might purchase methonal kit
Have gen 2 maf translator with 3" maf
Front mount intercooler with 3" pipe
New valve springs
160 t stat
Ford 9" rear end
Aftermarket trans cooler
Bluetooth scanner from John wales
Like I said i will replace the converter to match my setup. It will be a street/strip car..
60# injectors
8an fuel feel
6an fuel return
340 fuel pump
New valve springs
160 t stat
Ford 9" rear end
