Won't Start. Trying to Check Compression
Granny 2
I have a no start problem. The car has a possible blown head gasket. I have spark and fuel. Now I am trying to check compression (what a PITA) :mad: but with the fuel still being pumped into the cylinders I think the oil is being washed off the wall. What would be the best thing to stop the fuel while cranking? Fuel pump fuse, relay or something else? :confused:
Even though I have spark can the crank sensor be the problem? :D
Unplugging the fuel pump would be an easy way. Unplugging the orange wire at the batery should work, too.
