WTB: 70mm TB plenum 4 BGC intake
QWIKWE4
Anyone know where I can get a 70mm plenum to fit my BGC intake manifold? The bolt pattern is different than the stock style plenum.
Do you have a BGC plenum already? You just have to grind the hole bigger.
No I dont have a BGC plenum. Thats what I was looking for.
Does the Accufab fit on the BGC manifold?
The bolt on the rear of the BGC manifold for the plenum is about 1 inch farther back than a stock manifold.
Mine doesn't use an Oring seal.. don't think that I've seen one that did.
You "could" probably order one from Bowling Green customs.. now "southern customs".. but I WOULD NOT... I ordered fuel rails from them.. yes.. they sent them.. but 6 months later I started to get bogus credit card charges from them.. maybe they will ship COD.. otherwise.. you will need something custom made. You could get a plenum spacer and have a stock plenum welded to it.
John
Thanks for the heads up Eticket. I was thinking I would have to make something if couldn't find one that would work.
The BGC intake does use a oring and the 70 bolts right up- no grinding whatsoever- fits perfect.
plenum
champions plenum will fit your BGC intake, i have a champion and BGC intake , there is not much difference in them,
OC.. what's going on man? I still have the intake I bought from you on my car.
