needing a set of both the clips that hold the fuel injector to the rail, and, the wire springy clips that hold the wire harness plug onto the fuel injector.
if you don't have a complete set of 6 each, I need at least 4 of the clips that hold the injector to the rail, and 5 of the clips that hold the plug to the injector.
I'm also needing the 2 molded coolant lines that run to the throttle body.
I know this is small $$$ but hopefully one of y'alls won't mind going through your stuff and helping me out
