Yamaha Rhino starting issues
daviss
Does anyone know anything about ATV repair? The other day I tried to start the Rhino and nothing. All fuses checked out so I replaced the starter relay with the only one I could find locally and it is not a Yamaha OEM part. Now it starts but thestarter keeps cranking even after the engine starts and even after I shut off the ignition. It stops after a while, like 2 or 3 minutes. The only way to stop it is to unhook the power to the starter. I checked continuity across the relay and it has power even with the switch off. Faulty relay right? I don't want to go throwing parts at it. Any other ideas?
Any help is appreciated
Steve
