Misfires above 20 psi
Bear with me...I have searched the archives, I have cured this problem 12 times.
I think I know the answer...I would like your expert opinions.
Te61 Turbo set on KILL Wastegate ROD all the way In
100 Octane Unleaded
MSD 50lb injectors
Jim Testa Street Chip for 50s 19 deg. Timing I think
Ported Irons
Ported Manifold
Ruggles 210/205 cam
RJC Plate
Headers
Fuel Pressure set from 43-48 no change in problem
New Coil/Module
Checked Grounds and Positive and Neg cables...all good.
New R42 TS gapped at .035
Car runs like a raped ape....UNTIL you hit about 20-22 lbs of boost. Then it stutters, misfires, pops, farts etc.
O2s at this point from .780-.812
MAF seems to be locked at 254 as the scanmaster reads that reading from about 10lbs on up.
TPS .42 idle...4.2 WOT
Here is my theory....Is it possible that the street chip simply does not fuel the car enough to maintain boost levels this high? I get a little knock but nothing serious and the O2s are fine but at WOT they are only so good. I am curious if this chip is capable of supplying enough fuel to match the flow potential? How can I check to see if my injectors are maxed out. I had a similar problem with my 009s however that misfire was at 15lbs...I changed the coil and module at that time and misfire went away.
When the misfire went away I changed to 50s and started cranking the boost. I am going to turn the boost back down to a normal street level of 17-18 lbs and the car should run fine...it seems to only do it at the 20lb mark. Would a race chip allow me to run higher boost than this or do I need to go to an even larger set of injectors?
I have read several posts concerning MAF dropout and the Translator fixing this but if mine is locked at 254 then my misfire wouldn't be dropout would it?
Thanks in advance for your help. I know my post is long but I wanted to give all the information I could think of to save everyone from offering suggestions based on not enough information. Thanks.
100 Octane Unleaded
MSD 50lb injectors
Ported Irons
Ported Manifold
Ruggles 210/205 cam
RJC Plate
Headers
New Coil/Module
